11/20/2017 5:40 AM | |
Joined: 4/18/2014 Last visit: 3/5/2025 Posts: 255 Rating:
dear sir, The same problem am facing but the link which they were provided was not working, so please find my following queries 1.To communicate with the foundation field bus the s7300 CPU with dp-ff link is enough or we need to go for s7400 CPU with dp-ff link. because I found the manual which they are explained in DCS and S7400 but they not provided about s7300. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/20/2017 7:52:17 AMNew subject after splitting |
11/20/2017 10:28 AM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello GUWS I´m not sure if you can use it with S7300. I Only fioud these Information: https://support.industry.siemens.com/cs/ww/en/view/109480772 If you do not get an answer here you could try to open a Service Request at Siemens Support. Bye Murof |
