3/17/2020 12:24 AM | |
Joined: 3/6/2012 Last visit: 12/7/2024 Posts: 155 Rating: (18)
Hi khaikko, If you go online and save the parameters as a text file from that you can see all the menu and parameter ids. Have a look in the attached parameter text file. The menu and parameter ID numbers are in the column third from the right hand side with the heading ID. Regards, will4 AttachmentParameter Dump 6-21-2012 16-48.txt (576 Downloads) |
www.chbdrives.com |
