5/12/2020 2:38 PM | |
Joined: 4/28/2015 Last visit: 10/25/2024 Posts: 398 Rating:
Hello, thank you for your post! I checked the last version online and tested again with the attached file ‘Siemens.nc’ and I was not able to reproduce the described behavior. Please make sure, the ‘Siemens.nc’ file is selected directly by the browse window and that it is not edited (to anything not G-Code conform as described in the Info/Disclaimer section). Anyhow, the application library "Kinematics Language" (https://support.industry.siemens.com/cs/ww/de/view/109767009) enables to directly interpret the G-Code and execute the respective motion commands with TO Kinematics. Therefore, you could skip the GCode2MovePath tool and the download of the new DB to the controller. |
