11/17/2016 1:33 PM | |
Posts: 4 Rating:
Thanks! EDIT: I'm having problems sending the ON/OFF signal. My digital timer only sends analog signals, and i can't get that to work. The timer is a Grasslin talento 471 pro: Link I tried sending a digital signal (1/0) from an arduino board, but that didn't work either (I tried both digital pin and serial pin). I have set the P0700 = 2 to set terminal signals as command source. |
Last edited by: mdfenre at: 11/21/2016 9:51:38 AMLast edited by: mdfenre at: 11/21/2016 9:55:12 AM |
11/21/2016 1:33 PM | |
Posts: 4 Rating:
Ok, thanks for your quick response and helpful comments. I will try this out and hopefully it will work now. And thanks for clarifying that Jeff |
