8/26/2019 9:09 PM | |
Joined: 4/3/2019 Last visit: 1/24/2025 Posts: 4 Rating:
Hi, I have a question regarding G120, 1,5 KW. We had a problem recently which burned 3 inverters. The problem occured when we turned on the main power switch and just 2 phases energized the inverters instead of 3, damaging the devices. Can anyone please help me figure out what could be in this case? Thanks. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/27/2019 07:10:10New subject after splitting |
8/27/2019 3:21 PM | |
Posts: 61 Rating:
Hi, When you turn on the main power, the phase that is off, what happended to this phase? Its only disconnected? It was connected wrongly to the earth? This could be an earth fault, have you measured the voltage between phase and earth? Hope it helps.
