6/18/2019 3:53 PM | |
Joined: 3/28/2019 Last visit: 11/6/2023 Posts: 17 Rating:
I have G120 with Profinet. Is any way that I can convert it to Profibus? Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/19/2019 10:24:58New subject after splitting |
6/18/2019 4:14 PM | |
Joined: 9/27/2006 Last visit: 3/21/2025 Posts: 12344 Rating:
Hello; You have a G120 with a Profinet CU? Which model exactly? 1. You can change your CU for a Profibus CU230P-2DP, a CU240E-2DP-F, or a CU250S-2DP for example. 2. You can use the IE/PB link as proposed earlier with your existing CU. This application example shows how to program Profibus FBs for the G120, using Step 7 v5.5: SINAMICS G: Positioning a G120 CU250S-2 with S7-300/400 (STEP 7 V5) via PROFINET/PROFIBUS using Safety Integrated (via PROFIsafe) and HMI https://support.industry.siemens.com/cs/ww/en/view/68109071 Hope this helps, Daniel Chartier |
6/18/2019 4:36 PM | |
Thank You. I believe the cheapest solution is to change the CU with PB! |
