3/1/2021 10:35 AM | |
Joined: 10/11/2006 Last visit: 1/22/2025 Posts: 5985 Rating:
Please make sure that there is a functioning online connection to the G120C during the acceptance test. If this is the case it seems that there is something wrong. Result transfer requires a drive to be fully tested in order to work. You cannot compare the parameterization with a different drive if you do not know whether the initial parameterization is correct. https://support.industry.siemens.com/cs/document/109757227, A.2 describes how a manual acceptance test without tool support could look like. |
With best regards, |
