2/23/2013 5:47 PM | |
Joined: 3/21/2006 Last visit: 7/12/2023 Posts: 10221 Rating:
There is possible to use a S7-300C CPUs too. In other way take a look at CPU 312 . One thread in which has discussed almost the same issue. It will clarify the points. Best regards, Hristo Mihalev |
4/4/2019 4:32 PM | |
Joined: 10/11/2013 Last visit: 7/30/2019 Posts: 6 Rating:
I have same problem and search a lot but nothing was correct |
4/4/2019 4:39 PM | |
i found solution in TIA Portal V13 but not with S7 314 |
4/12/2019 11:37 AM | |
Joined: 12/9/2010 Last visit: 10/8/2022 Posts: 623 Rating:
Hi pratik7332, U can go through the manual in following link. In chapter 4, how servo/stepper is controlled with digital output is described. https://support.industry.siemens.com/cs/ww/de/view/12429336/en |
Last edited by: Jen_Moderator at: 4/12/2019 12:45:02 PMOptimized link. If you like the comment, rate it (right top) or thank it (left bottom). |
