4/19/2016 8:33 AM | |
Joined: 4/24/2006 Last visit: 2/7/2025 Posts: 8839 Rating:
Hello, You can connect your HMI panel to the network: How do you integrate an HMI operator panel into a local network? And perhaps some links: How do you log tags in an SQL database and read them out again with WinCC flexible? In WinCC (TIA Portal) and WinCC flexible how do you access an SQL database via a script? Best regards, Wizard |
2 thankful Users |
4/19/2016 7:43 PM | |
Hello, Did you look in the mentioned links about SQL-database. Perhaps that may help you. Best regards Wizard |
4/20/2016 5:01 PM | |
Joined: 4/18/2015 Last visit: 5/20/2024 Posts: 72 Rating:
Hi, I dont see the mentioned links about SQL-database. That is why I want to ask any way. |
4/22/2016 8:41 AM | |
Hello, You can open a CSV file, using Excel for example. Best regards, Wizard |
4/22/2016 2:14 PM | |
Joined: 5/28/2008 Last visit: 1/29/2025 Posts: 4518 Rating:
You can archive data on an external media and then open it on a PC. See this link. |
Ayman Elotaify |
4/22/2016 5:58 PM | |
What I want is to base on database I got, I can show it like data table at anytime on PC |
4/22/2016 7:01 PM | |
Hello, As I told you before.. Make the log you want weather it's alarm log or tag logging: How are tags and alarms logged in WinCC flexible?Then get it from Panel to a PC with excel application. --download the excel macro from the following link: How can you graphically display the contents of the tag archive of a Comfort Panel or the WinCC Runtime Advanced on the PC without WinCC (TIA Portal)? |
Ayman Elotaify |
