9/28/2011 3:18 PM | |
Posts: 2 Rating:
Hi, I'm a student from belgium, mechanical ingeneering. I'm trying to get an PWM output from a PLC S7-1200 with CPU 1212C. When I enable the pulse generator Pulse_1 and I compile the programme I get following error: ,Enable this pulse generator: Pulse outputs cannot be used for integrated relay outputs.,1,0,3:10:37 PM But I definitely did enabled this generator and already followed your example but even then I get the same error. Can you help me with this? Kind regards Splitted from TIP for S7-1200 und PWM. |
9/28/2011 5:02 PM | |
Posts: 89 Rating:
It looks like you have a CPU with relay outputs...? If so, you can not use puls outputs. |
11/17/2014 9:16 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4785 Rating:
3/9/2016 1:42 PM | |
New question published by mareq is split to a separate thread with the subject How can I manually create PWM logic?. Best regards |
