5/12/2020 9:22 AM | |
Joined: 6/17/2014 Last visit: 10/27/2021 Posts: 77 Rating:
Hi, I have this error when i want build image : root@debian:/home/jerome/meta-iot2050-master# ./kas-docker --isar build kas-iot2050-example.yml
Can help me ? Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/12/2020 10:40:16New subject after splitting |
5/12/2020 10:47 AM | |
Joined: 4/28/2015 Last visit: 3/12/2025 Posts: 578 Rating:
Does your user account have access rights to docker (user needs to be in docker group)? |
5/12/2020 4:45 PM | |
Hi, in attached the files. Thanks a lot Attachmentconsole.txt (1021 Downloads) |
5/12/2020 4:46 PM | |
and log_do install fileAttachmentlog.txt (1023 Downloads) |
5/12/2020 7:32 PM | |
Posts: 21 Rating:
Hi all! I'm having the same errors; Environment: Empty Ubuntu 20.04 virtual machine with Docker and Nodejs installed. I'm just following the instructions in the https://github.com/siemens/meta-iot2050 repo. My logs are attached. AttachmentIoT2050.zip (1000 Downloads) |
5/12/2020 8:28 PM | |
Are you running kas-docker as root or via sudo? That may not work. |
5/12/2020 9:00 PM | |
Posts: 21 Rating:
Via sudo, not root. |
