9/13/2013 12:35 PM | |
Joined: 10/10/2005 Last visit: 1/29/2025 Posts: 1940 Rating:
Hello, regarding to theprogramming method of calling blocks in SCL you will find informations in STEP 7 (TIA Portal), by "Instructions in SCL (S7-1500)". Further informations regarding the functions PUT and GET see the following FAQ: http://support.automation.siemens.com/WW/view/de/65975617 With best regards |
9/13/2013 3:13 PM | |
Posts: 24 Rating:
Yes, same thing! Can you please try it for yourself |
9/13/2013 3:19 PM | |
Joined: 7/7/2010 Last visit: 2/14/2025 Posts: 15653 Rating:
My current project is using GET/PUT with the s7 connection already configured, so when I added the get block into an scl FB, it acted properly. When I did the same in lad FB, it likewise acted properly. When I click on the diagnostic icon in the LAD GET block, it takes me online and helps me see I already had my s7 connection created. If you think it is buggy and find no workaround, send in a Support Request. If you find it is easy to work-around, making a note online how you worked around inconsistent behavior, that saves us all time by your sharing. |
science guy |
9/16/2013 10:17 AM | |
Posts: 24 Rating:
Thank you! I also have my S7 connection configured! I really don't know what is causing this issue.
I'll issue a support request |
6/18/2014 12:14 PM | |
KOP? |
science guy |
