4/3/2017 5:04 PM | |
Posts: 8 Rating:
Hello! Could someone help me? i'm searching and trying for a few days and I never get success. I'm using TP1200 as OPC UA Server and a Windows Server with Wincc RT V7.4 as a UA client. I want so get tag in Server from the HMI. I already enabled UA server in Runtime settings in Tia portal (tp1200) and I already fund once in OPC Scout a single variable. p.s. sorry for my bad English, and thanks for all support you can give ! ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 4/4/2017 3:07:56 PMNew subject after splitting |
4/4/2017 3:43 PM | |
Posts: 8 Rating:
Hello Murof! First I want to thank you for your attention. I already tried ip address and device name even different names / ip and every time I can easly ping, but never connect as I would like. Attached you can see what is happen to me. In-folder folder in Server nothing appears, in HMI (UA Server) I already move the path. Pictures: 1 -> Enabling the OPC UA Server 2 -> Chossing Port and None protection 3 -> In OPC Scout it can Find and identify perfectly no matter the Security Policy I choose 4 -> After add it, when I´m tryng to open give me the error 5 -> If I insiste, not always give me the same error 6 -> If I try to add to my tags manager (I think this will be my next step) It will find it but do not allow me to add. Can you find something wrong in this process? Thanks Again! Frederico AttachmentUA ServerIssue.zip (233 Downloads) |
