2/13/2019 10:21 AM | |
Joined: 11/29/2011 Last visit: 3/14/2025 Posts: 15 Rating:
Hi All, I am facing issue with CM PtP (6ES7 137-6AA00-0BA0) module as modbus master with S7-300 CPU. I am using FB640, FB641 for modbus master communication downloaded from the attached link. https://support.industry.siemens.com/cs/ww/en/view/75226762 when i initialize FB640 it get intialize without any error. but i am getting error W#16#8280 in the modbus master block, also when i raise request in the modbus master block i don't see and TX/RX Led blink. On doing further diagnosis with modbus master instance DB i have found the RD_REC is giving an error DW#16#C0809000. I am not able to find a solution to my issue, Can anyone please help on the following issue. I have attached my project code and screen shot of modbus master instance DB Thanks Regards Irfan ------------------------------------------------------------------------------------------ Attachment20190212.zip (211 Downloads) |
Last edited by: Jen_Moderator at: 2/13/2019 1:49:42 PMNew subject after splitting Last edited by: Jen_Moderator at: 2/13/2019 1:50:49 PMOptimized link. |
2/13/2019 10:22 AM | |
12/9/2020 2:44 PM | |
Joined: 1/13/2016 Last visit: 8/29/2022 Posts: 37 Rating:
Hi irfan.thakur, have you found the solution for tis problem? |
