12/7/2017 12:56 AM | |
Joined: 3/6/2012 Last visit: 1/20/2025 Posts: 155 Rating: (18)
Hi Peter, Unfortunately running hours and output KWH are not available as either a pick list item or output data ID (I checked in V5.4 NXG firmware). As an alternative you could use input MWHr which is manual ID 3668. For the running hours you could write some code into the DCS side that looks at the drive running indication and keeps a track of the hours. I have attached the NXG communications manual for reference. AttachmentNXG Communication Manual A5E02924901A_AC.pdf (1508 Downloads) |
www.chbdrives.com |
12/7/2017 5:28 AM | |
I have also attached the NXGpro communications manual for reference.
AttachmentGH180_NXGpro Communication Manual.pdf (1292 Downloads) |
www.chbdrives.com |
