1/25/2018 2:18 PM | |
Posts: 23 Rating:
Will a Profibus tester give you a distance to where your cabling fault may be? Thanks. Jim ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 1/25/2018 3:17:46 PMNew subject after splitting |
1/25/2018 8:02 PM | |
Joined: 9/27/2006 Last visit: 3/23/2025 Posts: 12344 Rating:
Hello Jim; As pointed out by IsaSalimi in your earlier thread, a diagnostic repeater is able to return information on the distance to a reflection point on the bus ( a wire break, or a short-circuit for example) either from the repeater position or to a close node. See this extract from the Diagnostic Repeater manual: Diagnostic Repeater for PROFIBUS-DP - Industry Support Siemens Hope this helps, Daniel Chartier |
