1/25/2007 11:15 AM | |
Posts: 25 Rating:
In the Graphics Designer of WinCC after a couple of minutes the message about XREFs.exe appears and afterthat it shuts off. What could be here the problem? |
1/25/2007 11:45 AM | |
Posts: 1275 Rating:
Hello Riaz, Are you using CrossReference? Could you post your logs here? Best regards, Danielle |
1/26/2007 1:53 PM | |
Posts: 25 Rating:
Hello Nice Danielle, Here I am again. Thanx for your reaction.... Here are some logfiles I found... I hope u can tell some more about what could be wrong... Thank u... Attachmentlogfiles.zip (36 Downloads) |
1/26/2007 4:39 PM | |
Posts: 1275 Rating:
Hi Riaz, What's your system configuration (client - server, etc.)? What areyour WinCCand Windows versions? I found this thread, which may help, since that error was in your logs. There are some other errors as well, like: ACCESS_VIOLATION - check this thread out. ActionOverflow:more than 5000 Actions to work - you may find info on that here. ExecuteError in Action - you may find info here. You shouldclear those errors as well. With APDIAG you can have a diagnosefor your scripts in runtime. Best regards, Danielle |
1/26/2007 4:47 PM | |
Posts: 25 Rating:
Hi Danielle, Thank u very much ... I'll check those errors... Best Regards, Riaz |
