2/27/2006 12:05 PM | |
Posts: 3149 Rating:
Hi Peter, with "GetProp" you can read the group name and then create a variable.. In WinCC online help you can find more info about GetProp Another nice FAQ:[:)] http://support.automation.siemens.com/WW/view/en/11868924 Nemo |
3/6/2006 3:21 PM | |
Joined: 1/17/2006 Last visit: 8/29/2023 Posts: 799 Rating:
Hi Peter, Why do you work with a grouped object and not with a customized object? This will make life easier. Jaap |
3/8/2006 12:07 PM | |
Posts: 83 Rating:
Hi Jaapie, I have to use group object because WinCC VBA can only work with group object, not customize object. cheers, Peter |
3/9/2006 1:51 PM | |
Yes, I think so, because it is possible. We use it all the time. Works the same for C-scripts. |
