6/20/2011 9:46 AM | |
Posts: 20 Rating:
Hello, does anyone know please, where to find gsd file for 6es7 315-2eh14-0ab0 firmware version 3.2? Thank you for answers in advanced. Vit Ulicny |
6/20/2011 9:55 AM | |
Posts: 378 Rating:
Hello, i think with the following link you will find what you need. PROFIBUS GSD files : SIMATIC Best regards Bilao |
6/20/2011 4:08 PM | |
Posts: 20 Rating:
Hello, thank you for your replies. Unfortunately I was not able to find the right GSD file. Please do you know any other sources, where I could try to search? |
6/20/2011 4:37 PM | |
Posts: 1547 Rating:
Hello, if you configure the CPU315 within the same Step7 project as the DP Master Station you can use in hardware catalog the entry "PROFIBUS DP --> allready configured stations" and select the right station (your S7 315). In other case you can create your own gsd file with the configured station and imoprt this GSD in other project. "Options --> create GSD File for I-Device" Regards Rated X |
2/1/2019 5:09 AM | |
Posts: 3 Rating:
Hello Does anybody know where can I download the GSD file of CPU 315-2 DP(67 315-2AH14-0AB0)? Thanks so much! |
2/1/2019 5:28 AM | |
Joined: 12/18/2014 Last visit: 6/10/2023 Posts: 30003 Rating:
Take a look at this web page: |
2/1/2019 7:54 AM | |
Posts: 3 Rating:
Thanks ixo65: I have download the file of 6es7 315-2ah14-0ab0 and have already installed it , but why I can't see it in the catalog? My step 7 version is V5.4+sp2 |
Last edited by: Martin ho at: 2/1/2019 7:55:52 AMLast edited by: Martin ho at: 2/1/2019 7:56:29 AM |
2/1/2019 8:05 AM | |
hi, as per the technical data, you need to install the HSP218. GSD file are normally needed to project the CPUs as slave. HSPs can be downloaded here: hope this helps, regards, |
FCK WAR! |
