6/17/2008 12:30 PM | |
Joined: 9/27/2006 Last visit: 6/1/2023 Posts: 12030 Rating:
Hello arnis; Here is the last version we uploaded for the Simeas P50 we used in a project last year. Please look at the readme file to see if your part no. matches. Hope this helps, Daniel Chartier AttachmentSIMEAS_P_V0220_GSD.zip (1332 Downloads) |
6/17/2008 12:52 PM | |
Posts: 4 Rating:
I just found a link to a newer gsd file on a german siemens page. http://www.powerquality.de/pq_da/html_nav/ind_dev_d.htm Could not find anything on the english siemens page. I hope it works, not sure why it has IO in the file name. I've attached the file for those who might need it. Thanks for the help dchartier. AttachmentSIMEAS_P_IO_GSD_V0310.zip (1063 Downloads) |
1/29/2009 2:52 PM | |
Posts: 5822 Rating:
Hello, if you read this manual you see that the Slave receives a configuration (Point 4.) about the values to be measured. I fear the universal module you use does not provide the required capacities. AttachmentInstruction_SIMEAS_P_in_SIMATIC_MU_280202.pdf (900 Downloads) |
1/29/2009 3:24 PM | |
Joined: 12/20/2008 Last visit: 4/7/2023 Posts: 19 Rating:
Great.....i have chosen type three and now is working properly with any BF. I really thank you very much |
