5/12/2008 11:02 AM | |
Posts: 672 Rating: (57) |
Hi, All necessary GSD files should be supplied on the ToolBox CD that comes with the system. You need to look on the Step 7 forum for an answer to your connection query but I do not think that there is an answer because I believe there are only 16 bit usb to pcmcia converters available. You will probably have to buy a new usb mpi port or I splashed out on an IBH Net link ethernet mpi port |
