4/10/2012 2:43 PM | |
Joined: 11/28/2011 Last visit: 10/24/2022 Posts: 53 Rating:
I have this problem aslo any idea? Thank you |
4/20/2012 12:23 PM | |
Posts: 58 Rating:
Dear Mahendra, You can download the GSD file from the following link (depending on which version of firmware you are using in your CF card of CU310). https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&objId=49217480&objAction=csOpen&nodeid0=21901735&lang=en&siteid=csius&aktprim=0&extranet=standard&viewreg=WW Regards Ajay Gupta |
4/20/2012 12:24 PM | |
Posts: 58 Rating:
Dear Martina, You can download the GSD file from the following link (depending on which version of firmware you are using in your CF card of CU310). https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&objId=49217480&objAction=csOpen&nodeid0=21901735&lang=en&siteid=csius&aktprim=0&extranet=standard&viewreg=WW Regards Ajay Gupta |
4/20/2012 12:31 PM | |
Thank you but this is not right :( my is 6SL30400LA010AA1 |
4/20/2012 1:01 PM | |
Posts: 58 Rating:
Dear Martina, Sorry for the goof up. You can find the GSDML file in the CF card in path SIEMENS\SINAMICS\DATA\CFG\ Have a nice day! Regards Ajay Gupta |
4/20/2012 1:04 PM | |
Ok :))))))))))))))))))))))))))))) Thank you |
11/23/2013 6:01 AM | |
Joined: 7/29/2013 Last visit: 12/20/2022 Posts: 7 Rating:
can anyone send me the gsd file for 6SL3040-0LA01-0AA1 PROFINET for TIA Portal |
