10/26/2020 2:08 PM | |
Joined: 10/11/2006 Last visit: 4/17/2025 Posts: 6008 Rating:
Hello, you have to switch between MC_GerinPos and MC_MoveRelative. 7.16.2 Override response V5: Synchronous operation jobs (S7-1500, S7-1500T) https://support.industry.siemens.com/cs/ww/en/view/109766462 The synchronising possibilities are described in chapter: 4.2 Gearing with "MC_GearInPos" with specified synchronous position (S7-1500T) 4.3 Synchronization (S7-1500, S7-1500T) https://support.industry.siemens.com/cs/ww/en/view/109766464 |
With best regards, |
10/27/2020 1:37 PM | |
Hello, same with Simotion. Change between gearing and _move() movingMode=Position_CONTROLLED) 2.2.1 Gearing Absolute gearing With absolute gearing (gearingType=ABSOLUTE), the synchronous operation occurs absolutely relative to the zero point of the master value and slave value, taking into account the gear ratio 2.2.5 Synchronization https://support.industry.siemens.com/cs/ww/en/view/109749950 |
10/29/2020 12:17 PM | |
Hello, this work with relative gearing, too. It is possible to switch between gearing and positioning or positioning and gearing on the fly. Helpful chapter: 2.2.1 Gearing 2.2.5 Synchronization https://support.industry.siemens.com/cs/ww/en/view/109749950 |
