1/27/2011 5:55 AM | |
Joined: 1/28/2009 Last visit: 6/10/2023 Posts: 6807 Rating:
Check this link: STEP 7 Hardware Support Packages (HSPs - as at 12/2010) for installing hardware updates in the Hardware Configuration also the procedure of how update hardware: How can you update the hardware catalog without direct Internet access? Check if the hardware you are using is supported by the version of STEP7 you are using. BR |
