9/11/2008 7:02 PM | |
Joined: 1/17/2006 Last visit: 3/29/2023 Posts: 551 Rating:
Hello guys ! Please, I need your help again. I have configured in "Hardware Config" a profibus net that you can see attached (image1.jpg). Theconsistency of the program is ok (no errors) how you can see in image1.jpg. But the problemappears when I delete the IM151-1 HF (P21 station) and I try to check the cosistency program or "compile and save" the new configuration (without IM151-1 HF). One error is showed but I don't know what is the problem. You can see the error in the image attached too (image2.jpg). What can I do to solve this problem ? Thanks in advance for any help. Best regards, Berg AttachmentET200S.zip (225 Downloads) |
Last edited by: Berg at: 9/11/2008 7:06 PM"Educate the children and it won't be necessary to punish the men." |
9/11/2008 10:36 PM | |
Hello, Attachmentcpu s7 317 f.zip (152 Downloads) |
9/12/2008 5:06 AM | |
Joined: 11/30/2006 Last visit: 3/16/2021 Posts: 118 Rating:
This is modified Hardware Configuration in which i have deleted theP 21 Station(Profibus Node 22) I hope this helps you. AttachmentDeleted_P21.zip (147 Downloads) |
9/12/2008 4:26 PM | |
Joined: 9/1/2005 Last visit: 5/24/2023 Posts: 4099 Rating:
Hello Berg, please try to upload your project. File size shouldn't be a problem. Limit is at the moment 4MB. Best regards CS Moderator |
9/12/2008 4:44 PM | |
Ok, thank you for the information. Here you are ! regards, Berg Attachmenttest.zip (164 Downloads) |
