11/30/2009 9:25 AM | |
Joined: 10/7/2005 Last visit: 6/5/2023 Posts: 2966 Rating:
Hello bin051 I presume your problem relates to the DP Master PLC going into STOP mode, am I right? If so the following FAQ and links contained within it shallhelp you: Which organization blocks do you have to load into the CPU to ensure that the CPU does not go into the "STOP" status when a remote I/O fails? I hope this helps and don't forget that <F1> will get you context sensitve help on each OB. |
11/30/2009 4:16 PM | |
Posts: 11 Rating:
Hello Fritz! Will I programming in OB86? You can guide me how to program in this OB! Thanks! |
11/30/2009 4:37 PM | |
Joined: 3/21/2006 Last visit: 4/12/2023 Posts: 10221 Rating:
Hello,
You could look at System Software for S7-300/400 System and Standard Functions (from 57th page) With regards, Hristo Mihalev |
12/4/2009 12:09 AM | |
Posts: 11 Rating:
Thanks everybody very much! I will try!!! |
