3/9/2016 5:13 PM | |
Posts: 22 Rating:
Another screenshot for my problem |
3/9/2016 5:14 PM | |
Posts: 22 Rating:
Another screensot |
3/10/2016 9:48 AM | |
Posts: 22 Rating:
Hello, Thanks for your answer. It is very interresting. Now, I switched 5 times OFF/ON for the bloc MC_Power with the switched OFF/ON for the bloc MC_MoveJog and he doesn't work. Fisrt: Switch ON MC_Power Second: Switch ON MC_MoveJog I tested with contacts It's normaly than all bloc is green even all switched is OFF? Did he miss some things? CommandTable? In attachement, any new screenshot with your answer. I add setting for this axis I'm a begginer for TIA Portal. Kind regards Kevin AttachmentScreenshot.zip (75 Downloads) |
Last edited by: Activefood at: 3/10/2016 9:59:57 AMLast edited by: Activefood at: 3/10/2016 10:17:21 AM |
3/10/2016 10:44 AM | |
Posts: 22 Rating:
Now it's worked, the volocity is too low |
3/14/2016 8:36 AM | |
Posts: 22 Rating:
Ok, I understand. Thank you for your helping. Activefood |
1/18/2017 4:41 AM | |
Posts: 1 Rating:
hi , how did you solve your problem? im new with tia portal and siemens; I think I have similar probleam. best regards |
