3/30/2022 3:40 PM | |
Hello s27 What do you mean with SCADA? SCADA Systems in SIEMENS product portfolio are mostly PC based process control software like WinCC V7.X, WinCC Professional Runtime (TIA Portal ) or WinCC Unified PC Runtime (TIA Portal). But there are also near machine HMI like Simatic Panels or similar: https://new.siemens.com/global/en/products/automation/simatic-hmi/hmi-software.html If you know what you want/need then we can answer more detailed question. Bye Murof |
3/31/2022 7:40 AM | |
Joined: 6/15/2020 Last visit: 1/16/2025 Posts: 175 Rating:
What do you mean with SCADA? SCADA Systems in SIEMENS product portfolio are mostly PC based process control software like WinCC V7.X, WinCC Professional Runtime (TIA Portal ) or WinCC Unified PC Runtime (TIA Portal). I mean this. |
4/13/2022 10:25 AM | |
Hello s27 A good start would be reading the manuals, checking for Getting started: https://support.industry.siemens.com/cs/de/en/view/72927729 or looking for a demo project: https://support.industry.siemens.com/cs/de/en/view/109746940 But the best start you get by joining a siemens workshop like the SITRAIN workshops. Bye Murof |
