3/25/2008 9:19 PM | |
Posts: 1 Rating: (0) |
Hello, When I Want To Run "LAD/STL/FBD programming S7 Blocks" From This Path: 'Start>All Programs>Simatic>Step7>LAD/STL/FBD programming S7 Blocks' This Error occured: { S7kafapx.exe - Bad Image This Application or DLL C:\Program Files\Step7\S7bin\ot01600603AS.dll is not a valid windows image,Please check this against your installation diskette. } And When I Want To Run LAD/STL/FBD In Simatic Step7(e.g. to open the OB1),Error Message 256:26 Occured (Internal OLE error Occured) Would You Mind Help Me To Run This Program? I Installed Step7 Professional On My Laptop With This Specification: Sony-VAIO FZ290N5 O.S. : Vista -> I Removed It& Install XP Professional SP2 Help Me Please, Thanks.... amir_rafieian@yahoo.com |
3/25/2008 10:41 PM | |
Posts: 2661 Rating: (279) |
Check the following FAQ: How do you clear message 256:26 "An OLE error has occurred"? http://support.automation.siemens.com/WW/view/en/10208766 Also check the following thread in the Forum: /tf/WW/en/Posts/1049 |
