8/13/2013 1:36 PM | |
Joined: 4/24/2006 Last visit: 2/17/2025 Posts: 8850 Rating:
Hello Tan2013, Perhaps this link might help: WinCC flexible: Engineering with Recipes Using Integrated Functionalities When you want to change the storage location, it should be done in WinCC flexible engineering software. You can store the Recipes on a local network. how do you integrate an HMI operator panel into a local network? Then all panels can look at the same directory (file) Best regards, Wizard |
8/13/2013 1:41 PM | |
Posts: 3037 Rating:
Hello, You can storage your on a MMC card on your panel. You can change your storage path in your project under your recipe > Properties > Data Medium > Path. Tweety |
