7/30/2009 8:29 AM | |
Joined: 4/5/2006 Last visit: 8/13/2023 Posts: 642 Rating: (131) |
Hello, you can use FC100 (CPU941-944) or FC101 (CPU928B/948). But its better when you modify your program and use FC105. from TI-S7 Converting Blocks. Adresses are almostthe same. DD101 -> DBD202. Regards
André Räppel --------------------------------------------------------------------------------- www.raeppel.de work faster withinnovative PLC-Tools |
7/30/2009 8:50 AM | |
Hello, i mean FC105 (SCALE)from TI-S7 Converting Blocks. Please select the block and press F1.You are using F60.1 - 60.3? Regards
7/30/2009 9:07 AM | |
Joined: 3/21/2006 Last visit: 10/7/2024 Posts: 10229 Rating: (1181) |
Hello, And explanation for FB31 AE:460 you'll find in Supplement Basic Functions Standard Function Blocks(from page 55th ) This will helps you to understand how to "go" to FC105 in Step7. Regards, Hristo Mihalev |
7/30/2009 9:21 AM | |
Posts: 15 Rating: (0) |
thanks everyone! |
7/30/2009 9:56 AM | |
Posts: 8946 Rating: (999) |
You are welcome. If you has further questions, just ask. |
