1/4/2019 3:47 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello you can use the build in Loggin system for logging your values. If you want to have a customized csv File then you have to use a CV Script Comfort Panel: https://support.industry.siemens.com/cs/ww/en/view/59604194 Advanced Runtime: https://support.industry.siemens.com/cs/ww/en/view/106501825 If you want to add the lines to the existing files then use the Mode 8 when you are opening the text file to append. Bye Murof |
