2/25/2012 8:35 PM | |
Joined: 8/31/2010 Last visit: 1/18/2023 Posts: 1496 Rating:
Hello Andy, You can use the 0-20mA channel to measure your 4-20mA current, only thing you need to do is as you said ignore the values less than 4 mA. For your totalizer - see her something similar to that: How is numerical integration for the S7-1200 programmed in STEP 7 (TIA Portal) V11? |
Like it? Rate it! |
