8/13/2007 2:21 PM | |
Posts: 1084 Rating:
Hi, Have a go with this zip file. It's a direct link from Salma's website (http://www.wincc.net) you could check that one out also. And there are also samples in the fourm. With regards, Ikkezelf |
8/14/2007 10:04 PM | |
Joined: 5/19/2006 Last visit: 8/5/2023 Posts: 547 Rating:
First of all, pubs and nortwind samples databases are not part of mssql 2005 distribution. You can download from msft here Runmsi file, copy db files into \MSSQL\Data folder and attach to your WINCC instance in SQL Server Management Studio From here Salma's code should run fine, see attached. I would suggest you to hire a consultant firm if you want to save some time for your big project. Dec Attachmentvbs_db_pubs.zip (412 Downloads) |
8/20/2007 9:02 AM | |
Posts: 1084 Rating:
Glad to here that it suits your needs. with regards, Ikkezelf |
1/11/2008 4:55 PM | |
Joined: 9/1/2005 Last visit: 8/24/2023 Posts: 4102 Rating:
Hello Bheja, think you are looking for this [quote user ="Ikkezelf"]Hi, Have a go with this zip file. It's a direct link from Salma's website (http://www.wincc.net) you could check that one out also. And there are also samples in the fourm. With regards, Ikkezelf I've tested it today and it is working. Please try again. Maybe you are not allowed to open external internet pages like this? http://www.wincc.net/ Best regards CS Moderator |
3/6/2009 2:36 PM | |
Posts: 1275 Rating:
Hi, I'm not sure which example project you were aiming for, but I downloaded some example projects from Salma's website some time ago. I'm posting the DB query - DB_Manipulation_V6 project, which may be the one you need. Note that it's in v6, so you'll need to migrate it to your version before using. Best regards, Danielle Attachmentv6 - DB query - DB_Manipulation_V6.zip (526 Downloads) |
