8/1/2014 2:03 PM | |
Joined: 4/24/2006 Last visit: 2/14/2025 Posts: 8848 Rating:
Hello Rob Hill, Perhaps you can use scripting. Maybe the following links might help: how can you write data to a file or read data from a file by means of a script on a Comfort Panel with SIMATIC WinCC (TIA Portal)? how can you store tags/data records event-triggered with date and time in a CSV file? Best regards, Wizard |
8/4/2014 10:08 AM | |
Joined: 9/12/2012 Last visit: 1/27/2025 Posts: 5 Rating:
Thanks Wizard, Once I get a little time I will work through the example Cheers Rob |
