2/23/2024 7:50 AM | |
Posts: 31 Rating:
am using IPC477E 19'' Touch PN/IE that has Wincc Runtime Advanced V17.
3/1/2024 9:33 AM | |
Hello AutoGen_5819022 Use the Signals in a DB in the PLC and then you can use a Discrete alarm also you could use an Analog alarm for this if you have the temperature value here are basic information https://support.industry.siemens.com/cs/ww/en/view/62121503 bye Murof |
Last edited by: Murof at: 03/01/2024 09:33:43If this Information really helps, you could use the Rate function |
