2/28/2017 3:45 PM | |
Posts: 648 Rating:
Dear nunobnk, Follow this link: https://support.industry.siemens.com/tf/de/en/addpost/162463/ There you can find the Technical data for this panel. With best regards rh1990 |
3/1/2017 1:54 PM | |
Joined: 1/6/2009 Last visit: 1/28/2025 Posts: 136 Rating:
Hi rh1990, You send me a wrong link. It is a link to add a post |
3/6/2017 10:49 AM | |
Joined: 5/28/2008 Last visit: 1/29/2025 Posts: 4518 Rating:
Hello, Here's the correct link for the technical data of TP1500: https://support.industry.siemens.com/cs/ww/en/pv/6AV2124-0QC02-0AX0/td And also you can view technical data for that panel and other panels as well in the attached excel sheet of the following link: What are the functional differences between the different SIMATIC panels? Hope this helps. |
Ayman Elotaify |
