3/7/2013 9:48 AM | |
Joined: 8/9/2011 Last visit: 11/2/2022 Posts: 323 Rating:
Hi.. My KTP 600 Monochromatics are getting damagedin some caseswhile downloading program to them if the power gets OFF while updating OS.I have uploaded damaged KTPs .Would i be able to retrieve them ? Thanks AttachmentKTP.zip (40 Downloads) |
"Any intelligent fool can make things bigger, more complex. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.":):) |
3/7/2013 10:00 AM | |
Joined: 3/21/2006 Last visit: 3/2/2023 Posts: 10221 Rating:
Factory Reset KTP600 PN |
3/8/2013 6:59 AM | |
HiUMENCHO I have gone all through the thread but may be my problem is exception. By following the procedure said i only get the message as in screenshot .No IP or MAC issue i checked .Also i have followed correct procedure regarding power OFF and ON while resetting to factory settings (OS UPDATE). THanks |
3/8/2013 7:30 AM | |
You can try withSupport Requestbut most probably you should send the panel for repaire... Best regards, Hristo Mihalev
