1/13/2012 4:13 AM | |
Posts: 26 Rating:
I use WinCC Comfort V11 +SP2 Before the error message I downloaded (or tried) a new program from WinCC to my panel. Today I was able to download my program to the HMI, but it doesn't run because of the error stated before. See attached my screenshots, hope it helps. Thank you! AttachmentScreenshots.zip (675 Downloads) |
1/13/2012 3:49 PM | |
Posts: 3037 Rating:
Hello, you must do an OS update with reset to factory settings. For this you must enterthe MAC adress of your panel in the transferdialog . See your picture Communication Error. See the following link. How do you do an operating system update (OS update) on operator panels? It is in german in the moment, it is translated in english. Tweety |
2/1/2012 12:11 PM | |
Posts: 3037 Rating:
Have you downloaded the newest image to the panel? If the image update with factory settings does not work, the panel is not ok. Doyoudo the following FAQ about image update with factory settingsstep by step? How do you do an operating system update (OS update) on operator panels?
You can see the message of the runtime in messageview in your project. You have not a messageview for messages of WinCE. You can only see the messages of WinCE if this message appears. Tweety |
6/4/2012 4:00 PM | |
Posts: 3037 Rating:
Hello, Doyoudo animage update with "Reset to factory settings"step by step? How do you do an operating system update (OS update) on operator panels? Tweety |
6/4/2012 8:05 PM | |
Posts: 14 Rating:
Hi, I got the same error "cant load PDATA.FWC" can not seem to clear it. Any advice? |
6/5/2012 4:34 PM | |
Posts: 3037 Rating:
Hello, You should ask the customer supportat your behaviour. ---> customer support Tweety |
