6/29/2023 2:54 PM | |
Joined: 5/6/2022 Last visit: 4/16/2025 Posts: 585 Rating:
Hi sersoporte, Mm I'm afraid that in a Basic panel it is not possible to make the calendar that you mention in the post. This is because the Basic panel is limited, for example it doesn't allow script. The calendar theme could be implemented in a Comfort panel. Here I share an example: "Toolbox for HMI Projects" Best regards! |
6/29/2023 4:54 PM | |
Posts: 29 Rating:
Thanks you! |
