10/17/2014 11:38 AM | |
Posts: 1058 Rating:
Hello Berry, seems like your operating system has been damaged. There is a possibility to reinstall OS and fix the problem, but it depends on Software you are using for MP277. For more informations look here: How do you do an "Operating system update" (OS update) or "Reset to factory settings" on operator panels? If you work with WinCC or TIA Portal, I would recommend you doing the reset with ProTool. Look inside the attachments on the page to check, which cable you need. regards |
10/20/2014 6:35 AM | |
Joined: 1/21/2013 Last visit: 11/20/2024 Posts: 4620 Rating:
Hello eisenpferdreiter MP277 reset OS with Protool? |
11/14/2014 11:06 AM | |
Joined: 10/17/2014 Last visit: 1/21/2025 Posts: 2 Rating:
ok thanks i`ll try it
