11/21/2024 11:35 AM | |
Joined: 8/3/2009 Last visit: 2/17/2025 Posts: 14760 Rating:
Hello fernando13 Check if there are some hints you have not tried so far: https://support.industry.siemens.com/cs/de/en/view/109800515 https://support.industry.siemens.com/cs/de/en/view/109961590 Which device version do you have set in the HMI project and which OS Version do you have installed on the Panel? bye Murof |
