8/30/2024 2:54 PM | |
Joined: 8/6/2018 Last visit: 4/16/2025 Posts: 366 Rating:
Hello, But you are getting an error, could you send us screenshots? Thanks you |
10/1/2024 1:16 PM | |
Posts: 2 Rating:
If the PIU installer does not work for you, please proceed as follows to install the V17 Upd8 images: Under the link below, item "1.2 Offline Installation Panel Images V17/V16 recommended for upgrade", you will find the panel images that can be installed without setup. These are described as TIA V16 and V17, but you can use those of V17 for TIA V19. You must unzip the zip file and copy it to the corresponding TIA 19 folder. The path for the correct folder can be found in the readme file for the panel images. Attachment109825750_Readme_Offline_Installation_Panel_Images_en.pdf (617 Downloads) |
