8/25/2016 9:41 AM | |
Joined: 6/26/2009 Last visit: 11/27/2024 Posts: 122 Rating:
Hi everyone, I been searching for a few days how to handle the problem that it is not possible for a Win.CE panel to access a file specified by IP address. ( \\nnn.nnn.nnn.nnn\map\file.ext ) . The filename has to be \\host\map\file.ext . If I am right , this should be handled by mains of a hostname resolution . On a CE system there is no LMHOST file as in normal windows . in the forum i found that it can be added in the registry with this key : HKEY_LOCAL_MACHINE\Comm\Tcpip\Hosts\<host name> Now I am looking for a solution to edit the registry in a TP comfort panel . Somebody who has done this before ?
