2/2/2022 10:34 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello AlphaGammaBeta you could try to work woth a workaround and not with the basic recipe view. You can create your own recipe screens. Here some basic example: https://support.industry.siemens.com/cs/ww/en/view/109739999 Here you can use multible screens for the recipe tags and the so called groups. With animation visibility you can also work with one screen and different "Tabs" like in browser or similar... but with basic recipe view its not possible Bye Murof |
