1/21/2015 5:07 PM | |
Joined: 1/21/2013 Last visit: 3/13/2023 Posts: 4617 Rating:
Hello Rajesh_s, There are several capacity increases in the panel 6AV2123-2DB03-0AX0 against 6AV6647-0AK11-3AX0, an example are the software, in the 6AV2123 the configuration is from WinCC Basic V13 against the 6AV6647 is from WinCC Basic V11 SP2 other example are the 65536 colors against their 256. if you download the two Product data sheet to find the differences in: Display - Backlighting - Memory - Clock-Interfaces - Languages - Functionality under WinCC (TIA Portal) - Message system - Recipe administration - Variables - Image object - Complex image objects - Lists - Archiving - Security - Process coupling-I/O options Product data sheet 6AV2123-2DB03-0AX0 - Industry Mall - Siemens Product data sheet 6AV6647-0AK11-3AX0 - Industry Mall - Siemens Hope this help |
