2/8/2019 3:47 PM | |
Hello Check also if the Panel image in the HM iProject is on the newest Version. Its because the PLC Sim in the newer Versions for example V14, V15 and V15.1 needs a new Panel image: https://support.industry.siemens.com/cs/de/en/view/109742764 Bye Murof |
