2/27/2014 8:35 AM | |
Posts: 1299 Rating: (136)
Hello, yes, in simulation this won't work. you can't change the direction of the object slider. if you really need it horizontal, you can make your own slider. see this application: http://support.automation.siemens.com/WW/view/en/48052573they made their own gauge with a graphic IO-field. you can do this analogical. or you add an object, e.g. a rectangle and move this dynamically with an animation. K!ke |
1/21/2016 2:00 PM | |
Joined: 4/26/2012 Last visit: 9/11/2024 Posts: 1552 Rating: (167) |
try this. to modify the brightness. I tested here and it worked. I tested in a TP1200, I believe in a TP700 work well.
AttachmentDesktop.zip (737 Downloads) |
Last edited by: rdoliveira at: 1/21/2016 2:01:57 PMLast edited by: rdoliveira at: 1/21/2016 2:02:38 PM"Always make a backup before and check the best time before testing." |
