11/19/2019 4:04 PM | |
Posts: 7 Rating:
Can you please help me, how can I connect SQL Server with WinCC Pro v.15.1. I just want to have data logs and alarm logs but it is different from WinCC advance when I want to define Databank for the tags. I have to use C scripts or VB script? has anyone any sample program?
Last edited by: Jen_Moderator at: 11/20/2019 09:35:37New subject after splitting |
11/20/2019 11:34 AM | |
Posts: 7 Rating:
thank you. I checked all the things that you said. But every thing is right. In addition there is something strange. When I try to reach the ODBC through WinCC advance ver.15.0, everything is fine. but when i want to reach the ODBC through WinCC pro ver.15.1 with VB script, the WinCC can't know the data bank and give me some error! I think my WinCC can't connect to this script correctly
11/22/2019 3:15 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Have a look: Bye Murof |
