2/3/2016 3:33 PM | |
Joined: 2/26/2015 Last visit: 3/4/2025 Posts: 1 Rating:
Hi .Sir
I need to help your technical support about S7MODM3 FUNCTION BLOCK.
My project need to communicate using MODBUS RTU with S400H & CP341.
The information that should be made are as follows.
Slave ID : 1(1 device) Function Code : 4(Input resistor) Address : 502~543(42 resistor) 1018(1 resistor)
Then I made chart as an attachment file.
But Data of 1018 address is not normal status.
Was this wrong configuration?
I would like to know the configuration method information when I do to recieve data from separate address on one device.
Thank you. AttachmentMODBUS_MASTER.pdf (113 Downloads) |
Last edited by: dpchoi at: 2/3/2016 3:33:44 PMLast edited by: dpchoi at: 2/3/2016 3:34:51 PM |
